Re: Farmall BN 12 volt
Posted by Bob M on January 30, 2009 at 11:10:51 from (151.190.254.108):
In Reply to: Farmall BN 12 volt posted by BobPA on January 30, 2009 at 11:05:59:
Bob - The 1N4005 is identical to the 1N4001 only it has a PIV (peak inverse voltage) rating of 600 volts instead of 50 volts. It'll work fine!
Tip: To protect the diode in the event of a short circuit wire a 10 ohm to 30 ohm, 1 watt (or greater) resistor in series with the diode.
This post was edited by Bob M at 11:32:56 01/30/09.
