Re: Farmall 230: low oil pressure/leaky filter case
Posted by El Toro on January 31, 2009 at 03:59:51 from (205.188.116.73):
In Reply to: Farmall 230: low oil pressure/leaky filter case posted by RandyM on January 30, 2009 at 19:44:24:
third party image
third party image
Is the oil level low? What weight oil are you using? Need to determine where the leak is, may be a gasket problem. Hal
PS: Need to make sure the battery is charging use a volt meter across the battery terminals and run the engine at 1/2 throttle or better. Should be 7.2 on a 6 volt system or 14.0 on a 12 volt system.
