Re: Capacity of Farmall A Transmission Case
Posted by Haas on January 31, 2009 at 06:15:30 from (12.65.18.55):
In Reply to: Capacity of Farmall A Transmission Case posted by Tom in Iowa City on January 31, 2009 at 05:21:14:
Fill until it comes out the level plug. Level plug is located behind the brake rod on left hand side of the transmission behind the brake rod on the left side. You will likely have to take the brake rod clevis pin out to get to the plug. Should take 4 to 5 quarts to fill it up. Don't forget the final drives which are separate from the transmission. Those don't have a drain. You have to remove the pans that cover the bull gears to remove the oil. The fill/level plugs are on the inside of the final drive near the drawbar bolts. I think they hold about a quart each.
