Re: Farmall 230: low oil pressure/leaky filter case
Posted by Janicholson on January 31, 2009 at 06:39:05 from (68.112.156.69):
In Reply to: Farmall 230: low oil pressure/leaky filter case posted by RandyM on January 30, 2009 at 19:44:24:
The groove at hte bottom of the filter case often seems like it is clean, when the fact is that there is a pyrolizzed square seal in the bottom. It is quite deep. if it is not removed (it could have been in there for the tractors "ever") it needs to come out. As indicated in the other post (El Toro) it could be low on oil, If you were working it hard with 10-30 oil 10# might be all it gets, but that is OK with good oil. Check that charging voltage, and get back to us if it is out of spec. JimN
