Re: H brake disc
Posted by ChadS on January 31, 2009 at 08:38:25 from (4.224.78.169):
In Reply to: Re: H brake disc posted by D Slater on January 29, 2009 at 13:11:06:
I want to correct myself on the 88 brake,,, its not a 88, the one to use for the M lambert disk breakes is off a MM UB. bout a 1/8 bigger around, which does fit, and its the same spline as the M-Lambert hub. On the heads,,,, kerosine heads for the H, I was thinking took a different valve than a gas H head. Reson for that might be how deep the chamber is on a kerosine head, VS the gas head, they moved the valves up higher in the head away from the piston, and did not change the actual overall thickeness of the H head. Im certain on the 8043DD head only being on any SH no matter the production year. Ive got a eary 53, and had worked on a late stage 2 SH and both had 8043DD heads. I know the 8043DD Sh head was an indetical casting to the 300-350 gas heads in design as far as the casting, Im 95% positive they take the same valves. 8043DD ports are not the same as a H 8043 gas head. The H gas head can yeild more cyl pressure when machined for best performance, but the 300-350 head will out flow the H head by quite a bit when a little port work is done. Chad
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
