Re: Farmall C engine temporary lock up
Posted by Red Dave on January 31, 2009 at 09:03:32 from (66.216.141.163):
In Reply to: Farmall C engine temporary lock up posted by SDP1 on January 31, 2009 at 08:57:06:
Likely the starter drive got jammed on the flywheel ring gear. Might be getting worn.
Take the starter off and shin a light in on the ring gear. If it has worn or missing teeth, you probably found the problem.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
