Re: Electric Switch Bad? Smoke!
Posted by Oak Dale on February 01, 2009 at 13:57:24 from (76.79.44.52):
In Reply to: Electric Switch Bad? Smoke! posted by Oak Dale on January 31, 2009 at 14:28:48:
Thanks for the input!
Ok, so here's what I found: The voltmeter has two 'lugs' or threaded rods for the wires to attach to. These lugs are theoretically insulated from the metal housing and mounts. One of the lugs had corroded and worked itself loose inside the meter housing, which is connected to (grounded to) the metal frame. When I jiggled the wires, it was bumping the metal and grounding itself and causing the heat (Smoke!) and/or sparking. The switch is fine. Blamed falsely. It was the meter.
So, we're back up and running, and I now need a new meter.
Thanks guys. This site is a godsend.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
