Re: 300 Utility - Change Front Tire Size
Posted by NewYorkTom on February 01, 2009 at 14:10:56 from (24.190.86.163):
In Reply to: Re: 300 Utility - Change Front Tire Size posted by redrider on January 31, 2009 at 19:31:43:
Thanks for the reply. If the rims were reversed did the tires rub the tops of the spindles? I have small reinforcement plates welded on the top outsides of the spindles. Do you have the same? Thanks. Tom
