Re: Super A touch control arm bolts? will regular bolt work?
Posted by rust collector on February 02, 2009 at 11:36:16 from (130.18.53.203):
In Reply to: Super A touch control arm bolts? will regular bolt work? posted by SteveNH on February 02, 2009 at 10:57:20:
The pins that connect the cultivator linkage to the touch control arm go in from the outside and are held in by the spring retainer over the rounded pin head. They are just long enough that the pin is flush with the indide of the lift arm. Using bolts will likely contact and damage the fuel tank when the arm is activated. They should be hardened pins and I believe are 3/8 inch diameter.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
