If you show serious foundational involvement, he should be finding a way to make it a sweet deal. Tell him you are participating in this forum. Also explain your intent to make it right and keep it in the family! Tell him you respect the price he sets and if it --can-- be met either in a lump, or over time, that you will do it. Tell him a bit of your finances if he does not know, so he can be fair. I'll add to the advice below. The oil pump is a built into the block. The tractor must be split to get at the pump cover. If the gears have worn into the bushing, and (thus) worn into the engine casting, it is tough to get it to pump well. Some parts (gear and shaft might be available, but I do not know where. Clearance the end plate with thin gaskets to .001 to .0005" when tightened. Prime the pickup by using assembly lube in the pump gears, and inject oil into the gallery until the oil filter is full with a small pump, or a pump oil can. Best of luck, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
