Re: Super A Coolant Question
Posted by CNKS on February 02, 2009 at 17:54:51 from (216.144.104.128):
In Reply to: Super A Coolant Question posted by Brian2 on February 02, 2009 at 17:37:28:
If the radiator cap "tongs" fit over the outside of the neck it is pressurized, inside non-pressure. The pressurized ones should have the level maybe an inch below the top. Non-pressurized are more likely to lose coolant until the proper level is reached. Pressurized ones are not "supposed" to until the boiling point of the water/antifreeze mix is reached. Well above 212 degrees. Put your hand on the cap, it will let you know if it is too hot -- no, I have never burned myself.
