Re: M HYD. PUMP IN FRONT
Posted by Janicholson on February 03, 2009 at 06:23:47 from (199.17.6.128):
In Reply to: M HYD. PUMP IN FRONT posted by logancorner on February 03, 2009 at 06:12:45:
Sure can be done.
Issues are that there needs to be complete replacement of the hand crank assembly. the boring and rebushing of the bolster base for either bushings/bearings or opening it up for clearance to allow a shaft to go through.
The use of a universal joint at the front of the crank is also a space issue. Making a drive from the crankshaft pulley to the U joint is pretty easy. It has been done, the fact that the M steering system uses that specific space is the hard fact.
If a person replaced the M steering with a wide front and hydrostatic steering, it might be a neat setup to machine out the casting, and mount a pump in the center of the lower bolster running straight into the crank W/O Ujoint. Just thinking out loud. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
