Re: M HYD. PUMP IN FRONT
Posted by Steven f/AZ on February 03, 2009 at 06:34:44 from (216.67.213.217):
In Reply to: M HYD. PUMP IN FRONT posted by logancorner on February 03, 2009 at 06:12:45:
Many different options, depending on how much hydraulic capacity and pressure you need. Also depends on how you are going to use the tractor. A cogged belt drive would be the easiest, provide the most power transfer, and have good longevity...
Chain drive works for slow-running use:
third party image
Not sure what they are using for a u-joint, but looks like it works:
third party image
Good for running power steering and a light hydraulic load - pressure is limited due to belt slippage:
third party image
Not live, but certainly more capacity and pressure than the belly pump:
third party image
