Re: Farmall A/Super A interchange
Posted by Jim Becker on February 03, 2009 at 06:55:22 from (71.252.139.51):
In Reply to: Farmall A/Super A interchange posted by Adrian Billheimer on February 02, 2009 at 21:32:38:
Part way through A production the oiling system was changed. This is when the oil slinger gear was added. I don't remember the serial number break. Quite a few parts will still interchange. The part number of the housing changed so you can tell them apart without disassembly. Check the parts catalog for details. The input shaft changed brtween A and Super A.
Hugh gives good advice on matching used gears. A lot of people will tell you you can swap in individual gears and they work fine. Usually true, but not a way to eliminate noise!
