Re: M HYD. PUMP IN FRONT
Posted by glennster on February 03, 2009 at 07:10:31 from (76.223.245.56):
In Reply to: M HYD. PUMP IN FRONT posted by logancorner on February 03, 2009 at 06:12:45:
i been toying with that idea too. i did some measuring, and if you remove the crank start unit, you can squeeze a pump in there, looked at some of the eaton pumps, and a couple will fit. also a log splitter pump. i figured to use a lovejoy coupling off the crankshaft instead of a u-joint, then run the hydraulic lines along the inside bottom of the frame rails. i think it would be a pretty slick setup. who knows, maybe somebody can put together a kit to retro fit these old rascals!!!!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
