Re: M HYD. PUMP IN FRONT
Posted by Armand Tatro on February 03, 2009 at 07:18:00 from (98.227.135.78):
In Reply to: M HYD. PUMP IN FRONT posted by logancorner on February 03, 2009 at 06:12:45:
If you remove the mud shield you will find a cavity in the casting behind the steering shaft. Facing the crankshaft is a fair sized acess hole with a smaller hole on each side big enough for a hose to pass through. I would think install lovejoy coupling on the crank shaft and put a pump in that cavity. I have been wanting to try that for a couple of years. Like has been said you would have to gut the hand crank parts.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
