Some more information on the Paul Some more information about the Paul Abot 3pt. hitch. I found pictures showing the cylinders mount over the top of the axel housings. Also there is a v-shaped bracket under the tractor with the point of the V attatched to the swinging drawbar pivot bracket under the tractor. Now if I can find my negatives I can get a cd made so I can post pictures on the computer. This could take a while! Armand
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
