Cub float level and Brass Needles
Posted by Dennis (VA) on February 03, 2009 at 07:54:31 from (66.82.162.21):
What is the proper float level setting for a IH carb on a 48 Cub?
Another question, when holding the upper carb section with the float and new needle installed, the needle occasionally sticks. I don't understand this as the cleaned carb has new seen gas yet. I wonder because the new needle is brass instead of steel it might not be heavy enough to drop correctly. I even tried blowing into the fuel entry to get the needle to drop. It didn't. Can you still get steel float needles, if so, where and does anyone think this will help. I have a similar sticking needle problenm with a old MF 202 which also is driving me crazy. Maybe TISCO kits are not up to snuff.
