Posted by LA in Wi. on February 03, 2009 at 08:45:01 from (71.117.37.127):
In Reply to: H throttle adjustment posted by labman98 on February 02, 2009 at 17:31:32:
I think I know what happened. I had my H steering shaft apart when we fixed the front end a few yrs ago. After reassembly, I had the same problem as you have. I discovered that somehow the whole vertical post in front of you, with the lightbar, the steering wheel, switches, etc. had moved forward (or backward, I forget which). If you can make the needed adjustment with that, I"m betting you will be ok. It"s a 1 1/2" pipe fastened on the bottom with 3 bolts and should not move, but check this out and see if that will help you. I really think in my case the steering shaft and etc. had been "worked on" years ago and was improperly reassembled and that post then had some forward or backward torque on it...just a theory. It looks like even a small 1/8-1/4" forward/backward movement will affect the throttle notches greatly because of how it is all mounted. Far better mechanics than I will look wildeyed at this idea...I usually can figure out what to do, but am not very good at bending wrenches. Writing checks for tractor work, now I"m real good at that. LA in WI
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
