Re: What year is this Farmall
Posted by Andrew Z on February 03, 2009 at 10:29:24 from (137.99.117.92):
In Reply to: What year is this Farmall posted by nick thomas on February 03, 2009 at 09:43:48:
you need the casting numbers that will say 10-12-Z or A, or B. or the actually serial number
Z =54 A=55 B=56
Andrew
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
