Re: External Regulator... or not
Posted by Bob M on February 03, 2009 at 10:55:35 from (151.190.254.108):
In Reply to: External Regulator... or not posted by Saw Dust on February 03, 2009 at 10:11:31:
Presuming your 2444 has a Delco alternator your quickest fix will be to replace the external regulator.
However if you are bent on swapping the OEM alternator for an internally-regulated unit you must make some minor wiring changes – whether you use the one salvaged off your Ford Ranger or obtain a Delco unit.
Personally I’d recommend the Delco. It will be a direct swap into the existing the mounting brackets. And you can swap the pulley from the original alternator.
A working Delco can be had for $15 - $20 at a junkyard. Or you can buy a reman at any auto parts store for under $40.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
