Re: 20.8-38's on a 1256
Posted by karl f on February 03, 2009 at 11:03:46 from (209.188.106.159):
In Reply to: 20.8-38's on a 1256 posted by Mark from WI on February 03, 2009 at 10:07:38:
we have 20.8 radials with tubes on ours (did not change the rims however). They are also full of fluid. if you have the short axles, the duals sidewalls will rub the main tire's sidewall. There really isn't any room to set the wheels in further due to fender clearance and the rim ring we have the hubs set on--might not be room for both the dual adapter and hub set to outer ring.
so far the only issues we have are the dual fitment. it raised the tractor a couple inches, but the old tires were co-op bias 18.4s that were nearly bald. we only use the tractor about 20-50 hours a year.
karl f
