Re: Farmall H Distributor Governor questions
Posted by Janicholson on February 03, 2009 at 12:08:35 from (199.17.6.128):
In Reply to: Farmall H Distributor & Governor questions posted by neblinc on February 03, 2009 at 11:25:12:
In my opinion the grease zerk is kind of a weird joke. It is explained, but really does not work.
The bushing it is "servicing" is, as you point out, not connected. If I were inventing it I would have made provisions for engine oil to be used to lubricate it, with a seal on the distributor end to keep it in. Or a oil hole and flip cap to lube it with real oil annually.
Well that is an interesting issue, I think I will drill a hole in my housings like it (when I get into one for other reasons) and make it a lube point with a cap or plug to keep out dirt.
The adjuster is probably an attempt to modify by a prior owner. JimN
