Re: Live pump return line
Posted by Bob M on February 03, 2009 at 12:36:28 from (151.190.254.108):
In Reply to: Re: Live pump return line posted by Cub n M in Or on February 03, 2009 at 12:30:01:
Ben - I've seen a couple different Super M's/400's work for years with suction lines cobbed from clear, soft vinyl hose and a pair of hose barbs. Not pretty, but it works.
The key is to make sure the hose is oil-resistant!
Bob M
