new 450 hyd pump
Posted by 756puller on February 03, 2009 at 17:22:11 from (70.41.128.147):
i replaced the hyd pump on my 450 to get it to steer better, i had it runnung just perfect then it would die all of a sudden, i took the distributer off and it looks like the tang just wasnt quite in the groove, i shimmed the tang so it was tighter and it hasnt missed a beat since, is there a hyd pump that works better in the drive than the a and i pump i put on?
