Posted by The tractor vet on February 03, 2009 at 17:39:28 from (76.212.225.98):
In Reply to: 806 steering, brakes posted by Ronnie Langford on February 03, 2009 at 17:15:26:
There are a couple things here that could be the problem ,(1) the O/Ring between the speed transmisson is old and hard and not sealing well or the last time someone had that tractor split they forgot to replace the O/Ring ,(2) the MCV pump is getting tired and not doing the job anymore . (3) you could have a sicking valve in the MCv or weak springs . So the cheap easy way is to over fill the system and this will take care of any air entering the MCV system and help on fluid pick up. IF this does not solve the problem then it is time to break open the piggy bank an d get a new pump and a seal and gskt pkg. for the MCV and a new spring kit and go thru the MCV . For this ya need to get at least a I T manual and a set of dial calipers and a pressure gauge and fitting to make the correct pressure setting .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
