Re: 806 steering, brakes
Posted by Brad in WI on February 03, 2009 at 18:26:44 from (24.164.253.14):
In Reply to: 806 steering, brakes posted by Ronnie Langford on February 03, 2009 at 17:15:26:
the gasket kit for the MCV pump is only $67 thru my CIH dealer, NON TA tractor but kit is for both (bought one last week) and not that hard to install. The power steering pump which installs inside the MCV may need to be serviced. This requires a hyd. shop to rebuild as parts on not available thru CIH. Remove the filter and try blowing air thru the inlet port by the MCV pump back to the filter. Worked for me when I had no oil flow. You can also try removing the filter completely and running the tractor to see if you have a faulty filter.
