Re: 240 hydraulic problems
Posted by PaulW_NJ on February 03, 2009 at 19:44:13 from (96.225.64.148):
In Reply to: Re: 240 hydraulic problems posted by IH fan on February 03, 2009 at 16:25:02:
Wow, that's exactly the same problem I'm experiencing with my 240U! I cleaned the screen, replaced the filter, rebuilt the hydraulic control valves, and replaced all of the O-rings between the pump and the control valve, replaced the pump's gasket, and it still foams out the breather until the level of fluid drops. I noticed the section of rubber hose in the suction line is kind of ratty looking, and wondered if air could leak in, while fluid wouldn't leak out, but didn't know if that was possible. I'll try the pressure test Jim suggested as well. Please report back what you find out, as the problem has been driving me crazy.
