Just do not let it go faster in TA than it would go in Direct Drive in any gear. The issue is overspeeding the TA case and clutch. it is OK to pull the TA back when under load, no issue. It is OK to pull it back on flat ground in high gear. it is not OK to let the tractor go faster in TA. and for the bigger tractor it is not OK to use it to Slow Down using engine braking even though it will (it tears them up). JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
