Posted by ScottyHOMEy on February 04, 2009 at 06:46:47 from (64.222.201.63):
In Reply to: Super C Governer posted by Dustin Hartmann on February 04, 2009 at 06:05:14:
There's a number of things that can cause that.
I've found it to be pretty common with replacement and rebuilt carbs when the arm on the throttle shaft is of a different length than the original. There should also be two springs on your governor control rod, one in front and one behind the block that connects the rod to the governor. Internally, worn, tired or broken springs can cause it. A bad thrust bearing can have the same effect.
Where you're hunting, one of the easiest things I'd check out first is the governor-to-carb link on the left side. With the motor stopped, find the rod that connects the carb to the governor and remove the pin and clevis at the front end where they attach to the governor arm. Then set your throttle lever (at the seat) fully forward. Go back to the carb and hold that rod and the governor arm both as far to the rear as they will go, without putting tension on the spring resistance you'll feel in the governor arm. Then thread that clevis (if everything is there, there'll be a jam nut up against it) whichever way it has to go so that you can get the pin back through the clevis and governor arm.
That may take care of the hunting-- if not there is another adjustment that may fix it, or you may have an internal problem in the governor.
And even if it takes care of the hunting, it may still not give you back full range on the throttle control.
There's a couple of the guys who have had some success with that by straightening and bending the control rod from the lever to the governor to change its length. I haven't had to do it, but maybe one of them will chime in with ideas in that direction.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
