Posted by mkirsch on February 04, 2009 at 07:17:19 from (64.80.108.55):
In Reply to: 240 hydraulic problems posted by Idaho Ron on February 03, 2009 at 16:00:59:
Is the oil liquid and slippery? Yes? Then it's good enough for testing.
Really, oil is oil. If you're somewhere near right on the viscosity, the hydraulic pump can't tell whether it's SAE10, HyTran, or extra virgin olive. Neither can the hoses, valves, or cylinders.
The major differences between the oils are the additive packages which do things like keep the moisture in suspension, or keep the sludge from building up.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
