Re: 1940 M
Posted by D Slater on February 04, 2009 at 10:26:21 from (71.164.55.189):
In Reply to: Re: 1940 M posted by TractormanNC on February 04, 2009 at 07:46:17:
6943 # is for a replacement block for early tractors before the R suffix numbers came along. your block was probably cast in 1942. Wish I could tell you why the numbers are ground off sometime, must have been different numbers than what they wanted on block, but don't know. Sometimes find them ground of with no numbers stamped back. I suspect the other poster has a block cast in 1956 which brings up another mystery. The cast # 365586 R1 replacement blocks can be found with any of the following, C-248, C-264 or C-281 cast on side of block, even though the cast # of block is the same. Hope this helps.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
