Re: What is the best series international?
Posted by mkirsch on February 04, 2009 at 12:22:55 from (64.80.108.55):
In Reply to: What is the best series international? posted by bdnc on February 04, 2009 at 11:03:14:
Sounds like the 1256 had a hard life before it got to you. Sounds pretty normal for a tractor that's been used hard and not maintained properly.
If you treat the tractor well you can get away with being a little lax in maintenance, but if you are hard on them, you've got to be right on the ball with keeping everything tight and straight or you'll end up with one problem after another after another until you're so sick of it that you're ready to condemn the entire line of tractors.
