Re: Which IH tractors had this rear wheel bolt pattern?
Posted by LenND on February 04, 2009 at 14:01:13 from (216.221.96.202):
In Reply to: Which IH tractors had this rear wheel bolt pattern? posted by John_PA on February 04, 2009 at 12:39:02:
I think the WD and WD45 have eight hole wheels cause the wheels off of my 95 JD combine will bolt right on. And they 26inch and eight hole.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
