Re: help!!! h giveing me fits!
Posted by Janicholson on February 04, 2009 at 16:46:55 from (64.83.193.190):
In Reply to: Re: help!!! h giveing me fits! posted by corysostrander on February 04, 2009 at 15:59:48:
I'll add that a high float level will mimic the stuck float. I think you will find the plugs have stopped firing across the electrodes. Pull them out and heat them with a propane torch to get the carbon off. Use only very fresh gasoline. Set the float level, it does not need to come off, just the bowl removed.
Very little choke may be needed to fire it up.
Turn in the load screw 2 turns from where it is. and go from there. Keep in touch letting us know what is happening. JimN
