Re: CRRRAAAAAACCCKK follow up
Posted by Hugh MacKay on February 04, 2009 at 17:44:03 from (64.228.11.23):
In Reply to: CRRRAAAAAACCCKK follow up posted by Vern on February 03, 2009 at 21:06:04:
Vern: I've been following this. Lay a section of plywood over open top of transmission. Get out my old stand by, cut off a broom handle, preferably one your good better half no longer uses. Start the tractor, and with one end of broom handle to your ear, place the other end against side of transmission, try different spots along transmission. By moving it around you will zero in within 2" of the problem. Believe me it never fails.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
