Criterion
Posted by Wild Bill Caldwell on February 04, 2009 at 20:28:46 from (65.0.46.29):
I've never seen this discussed on this forum....How do You judge good workmanship when You look at tractors that have been restored, or worked over, or worked on, or so on? What defines sloppy work versus Field expdiency? What do You think of steel fuel lines being replaced with stubs out of the sediment bowls and carb. with rubber hose and hose clamps between. I know how to judge firearm work, I have studied Jap. swords, engravein', buildin'guitars, I can inspect weldin' but what is the criteria for tractor work. There are times I've been at a tractor show or pull lookin' the tractors over and hear critical comments from others, have had a few confrontations from takein' exception to comments I didn't think was necessary or proper, it is easy to be critical of a Hand when You ain't the one A$$ deep in Bullagators lookin' for the swamp drain plug...You hands on this forum are some of the sharpest I've seen, I 'd like to know what You look for and over look
Wild Bill
