Re: Carb
Posted by Janicholson on February 04, 2009 at 21:34:03 from (64.83.193.190):
In Reply to: Carb posted by JG67 on February 04, 2009 at 19:02:22:
If it is running well, and not using massive oil, (and you are happy with the work it is doing) put a set of hotter plugs in it. Equivalent to Champion D21 is about as hot as available. Plugs that work, Of whatever brand, are good. I have no USA brand preference. Leaning the carb even more may be needed.
If you make it work, it will likely stay cleaner.
If it has fuel in it that is older than a month, it may get much better if new fuel is used. JimN
