PTO slip clutch
Posted by Gary Hutchinson on February 05, 2009 at 08:14:23 from (192.236.23.87):
Would anyone like to weigh in on why it may not
be a good idea to use a PTO slip clutch to do the job of a shear pin on an implement like a
snow blower? I can envision that adjusting for
the right tension might be a challenge, but I
thought if you start out on the light side and
tighten up a little at a time until you get to
where it doesn't slip anymore during normal
use, you should be OK. I haven't made enough
trips around the turnip patch yet to determine
whether this is smart or not. Thanks for any help guys.
