Re: Farmall Super C Battery Cables
Posted by Hugh MacKay on February 05, 2009 at 13:44:06 from (209.226.247.158):
In Reply to: Farmall Super C Battery Cables posted by Retcol on February 05, 2009 at 13:11:16:
Retcol: I'm assuming 6 volt, go 00 or 01 gauge and run the ground strap down to bolt screwing into a casting. I know it not original, but the sheet metal in the dash and battery box are not new either. I've started running every ground strap to cast, lot less problems with good ground. I like to run it down between battery and dash on offsets of SC, 200, etc. Attach it to bolt that holds the dash to casting, can't see it and looks just as original as new.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
