Re: Super C Governer
Posted by Jim Becker on February 05, 2009 at 18:09:55 from (71.252.139.51):
In Reply to: Super C Governer posted by Dustin Hartmann on February 04, 2009 at 06:05:14:
The Super C governor spring is shorter then the one in the B, could have some effect on where the lever runs at a given speed. But then, who knows what springs may be in there by now.
A loose shaft where Gene mentioned is likely piece of the story.
