Posted by Bob M on February 05, 2009 at 18:20:35 from (74.74.133.120):
In Reply to: Super A - Generator posted by Brian Luton on February 05, 2009 at 17:57:27:
Brian - The Super A will start reliably in the coldest weather with a well-maintained 6 volt electrical system. So unless your tractor is a daily worker, I'd stay with the stock 6 volt system.
A good system will charge 12 - 15 amps (about 2/3 right deflection on the ammeter) after startup. It sounds like yours is charging very little if it all. But before you tear into the generator, make sure generator is indeed the problem and not the regulator or wiring.
A quick test: Run a temporary jumper wire between the generator "F" terminal and a GOOD ground. Now run the engine at governed RPM and note the ammeter reading.
If the ammeter shows 12 - 15 amps the generator is fine - the problem is a bad regulator, a bad regulator ground or a wiring problem. But if if the ammeter's still centered then be looking for a generator problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
