Posted by mkirsch on February 06, 2009 at 10:34:29 from (64.80.108.55):
In Reply to: 1959 Farmall 140 posted by Janicholson on February 06, 2009 at 08:43:58:
Check more carefully. The distributor may be turned where the clips are not obvious, such as top and bottom. Can't say as I've ever heard of a distributor cap being held on any other way but clips.
Have you pulled a spark plug and checked for spark? You remove the plug, insert the bare plug back into its wire, and lay the base of the plug against the engine block. Crank the engine over and watch for a bright blue spark.
It may be the points, but it could also be any of a dozen other things unfortunately. The coil may not be getting power.
Have you checked to see if the tractor is getting fuel? I've personally forgotten to turn on the fuel at the sediment bowl under the tank SEVERAL times in the last few years. Tractor runs good for 30 seconds then suddenly and inexplicably quits and won't restart... Duh on me. I blame it on 30+ years of not turning the fuel off ever on the farm. Now that I collect them to play with, it's a new habit I'm still trying to form...
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
