Posted by TheDurk on February 06, 2009 at 11:41:55 from (72.68.35.191):
In Reply to: 1959 Farmall 140 posted by John T on February 06, 2009 at 08:43:58:
A METAL distributor cap? That would be a....surprise. So would a cap that does not use clips. Can you find the indentations in the cap where the clips would be?
Mkirsch has good advice. The first thing is to verify if problem is spark or fuel, then go from there--assuming you are sure no one has messed with timing or plug wire sequence since it last ran. . Cap and rotor are my first suspects in a 140 laid up for the winter if the problem is on the spark side. If you get a spark with the big coil wire to the block, but not with a plug wire, then it's a definite. I always keep a spare of both around because you cannot always tell if they are bad. (If they are good, I save the old ones from the last change).If you have no idea when they were last changed, swap them anyway. It's the first thing I do if I have a no-start problem in winter--I think the condensation gets to them. You can get them at NAPA or CaseIH.I have had a 1966 140 since Dad brought it home new from the dealer.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
