Re: Farmall 100 Questions
Posted by ScottyHOMEy on February 06, 2009 at 13:16:15 from (71.241.192.17):
In Reply to: Re: Farmall 100 Questions posted by Larry Kosin on February 06, 2009 at 11:11:43:
Yep, my mistake, there are three bolts holding it to the block. But if it is the stock manifold with no remote, there should be three plugs with recessed hex-heads on the raised arc, two 1/4" at each end and a 1/8" in the middle.
