Re: C221 Engine on 205 Combine
Posted by bc on February 06, 2009 at 14:48:54 from (69.149.215.139):
In Reply to: Re: C221 Engine on 205 Combine posted by noncompos on February 06, 2009 at 12:06:14:
Thanks noncompos. I'm just guessing it is a c-263. I can't match the block number and for all I know it might be a c-301. I'll search the online parts for the 301 and see what matches.
I've figured out that parts like the plugs, oil filters, carb, and dist. parts are pretty much the same for most of those 1960's tractors. Anyway I'm using a 263 oil filter and since most engines had an adaptor to go from the old cartridge in a can to the screw on type, they might all use the same filter anyway.
To get the needle valve for the carb I had to use the 656 ih tractor. Didn't know then that the engines were listed separately.
