Re: Farmall H high end miss
Posted by CNKS on February 06, 2009 at 14:54:58 from (216.144.104.128):
In Reply to: Farmall H high end miss posted by t martin on February 06, 2009 at 13:15:52:
Sounds like a lean mixture. Set wide open throttle, turn main jet screw in until rough, out until smooth plus about 1/4-1/2 turn. Do the idle the same way. Repeat as necessary until it will accelerate smoothly from idle to full rpm when throttle is moved rapidly from idle. Set timing by ear for max RPM. If that does not work and points are set at .020 and plugs at .023-.025, your carb is not completely clean, or you have a distributer problem, possibly worn shaft, etc.
