Re: 1959 Farmall 140
Posted by TheDurk on February 06, 2009 at 15:27:17 from (72.68.35.191):
In Reply to: 1959 Farmall 140 posted by Red Dave on February 06, 2009 at 08:43:58:
Hugh--I have electronic ignition on my 140. I got the Pertronix from this site but I looked around. All that I saw go inside the distributor, keeping the original cap and rotor. A fully computerized ECU with no distributor is possible, but it would require a sensor on the dist. shaft (or flywheel/crank) and an ignition module to substitute for the rotor and advance mechanism. Programming and mounting on a 140 would be quite a trick, I would think.
I assume '59 140 was born 6 volts, perhaps some major electronic surgery was done at time of a possible 12 volt upgrade. I still think a metal dist cap is unlikely--does such an animal exist in any application?? A cap has to be very non-conductive and I find it hard to imagine any metal could be suitable. I bet on spray-painted plastic looking like metal. Debi--a picture, please?
