Or you could stick with the grease. I do. Even if you change seals/gaskets it will probably leak again in four or five years. Just remember to pull the fill cap before you start pumping into that zerk--otherwise you can pop a shaft right out of the box. Then pump away until it comes out the top. Pro's recommend cornhead grease, but I use regular chassis grease on my lightly used 140.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
