Re: Steering play in Super A
Posted by Hugh MacKay on February 06, 2009 at 15:56:44 from (209.226.106.11):
In Reply to: Steering play in Super A posted by TreeFarmer1414 on February 06, 2009 at 15:26:31:
Tree Farmer: The vertical shaft in that gear box has two woodruff keys. First keys the half gear to shaft and second keys steering control arm to shaft. If bad enough those two keys alone can give 1.25 turns of free travel on steering wheel.
You mention end movement of steering shaft, that indicates the bearings on that shaft are worn.
